channel-group
interface-config-ge-instance
Assigns this Ethernet port to a channel group.
Ethernet ports can be aggregated to form a channel group. They can be aggregated to form
a minimum of one and maximum of two channel groups. A port can be a member of only one
channel group at a time.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Parameters
channel-group <1-4>
<1-4> |
Specifies a
channel group number from 1 - 4. The number of channel groups supported
varies with the device type. For example:
- NX5500 – Supports three
channel groups
- NX75XX – Supports four
channel groups
- NX95XX – Supports two
channel groups
nx9500-6C8809(config-profile-testnx5500-if-ge1)#channel-group 1
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
interface ge1
ip dhcp trust
qos trust dscp
qos trust 802.1p
channel-group 1
Related Commands
no |
Removes the channel group to which this port belongs |
